PXI modulus
Would you please tell me can I connect a PXI to personal compute?
Message Edited by Naser1363 on 06-06-2010 03:31 PM
(3,295 Views)
Hi Naser1363,
Yes, you can connect a PXI to a personal computer.
For a desktop computer, you have the following options:
  • PXI-PCIe8361 or PXI-PCIe-8362 - If you have PCIe slots available in your computer, you can connect to your PXI chassis with these cards and a MXI-express cable.
  • PXI-PCI8331 or PXI-PCI8336 - If you have PCI slots available in your computer, you can connect to your PXI chassis with these cards and a MXI-4 cable.
For a laptop computer, you have the following options:
  • PXI-ExpressCard8360 - If you have a newer laptop that has an ExpressCard slot in it, you can use these cards with MXI-express cabling.
  • PXI-CardBus8310 - If you have an older laptop that has a PCMCIA slot in it, you can use these cards with the StarFabric Cable kit.
Let me know if you have anymore questions.
Sara Lewandroski
Applications Engineer | National Instruments
(3,277 Views)
