PXIe-1071 and PXI-4461
I have a question hope NI engineer can answer. I used the PXI-4461 and PXI-4472 in PXI-1031 and PXI-1033, I have the PXI-1031 failed and NI response for not support for repair. The sale rep in Testforce suggest the PXIe-1071 is the replacement but he said the PXI-4461 and pxi-4472 won't work with PXIe-1071. But I found some info stating that PXIe-1071 will compatible with the PXI modules. I need the answer for the direction. Thanks.
(880 Views)
DSA modules are not recommended for PXI-1071 chassis. See NI 449x and 446x Chassis Compatibility in the PXI Advisor
Unfortunately, your choices are limited. You can either choose:
1. PXIe-1092 and PXIe-8360, since 1092 does not have a built-in remote controller, or
2. PXIe-1090 and a new PC with a built-in Thunderbolt 3 port (Connect PXIe System With Thunderbolt™ Interface Card).
https://tmesystems.net/
(871 Views)
