PXIe 1092 stuck in aptio setup utility at startup.
Hi, I am using PXIe 1092 chassis with modules PXIe 8840, PXIe 6355 and PXIe 4353 with TB 4353. After connecting the TB 4353 with thermocouple (k-type), I turned on the instrument, but the monitor is stuck in Aptio Setup Utility. I tried Restarting but no use. Kindly let me know how to exit the setup utility. Thanks in advance.
(1,648 Views)
There are multiple options to purchase PXIe-8840.
  • Windows 10 64-bit
  • NI Linux Real-Time
  • Phar Lap (Real-Time OS)
Whichi option did you select?
Certified LabVIEW Developer
GCentral
(1,643 Views)
Its Windows 10 64-bit
(1,638 Views)
The instrument was working fine before connecting the thermocouple. Not sure if that could influence. However, I have disconnected it too. How can I quit the Aptio Setup Utility.
(1,580 Views)
Very strange behavior. TB-4353 is just terminal block, you don't need any software driver to use it.
It means that TB-4353 shouldn't affect to controller behavior.
Do you have any wire connection in TB-4353? If you have, why don't you remove all wires and try again?
GCentral
(1,570 Views)
