PXIe 5160 NI-DAQmx - creating physical channel - no supported devices found
I use PXIe-5160 to measure the Voltage. The self-test and test panel display well, also display well on Windows device manage. But when I use NI-DAQ>>Acquire Signals>>Analog Input>>Voltage, it said no supported devices found.
I am using LabVIEW 2021 version. Could anyone tell me why?
(920 Views)
Accepted by topic author Healthy
5160 is an oscilloscope, you need to use NI-Scope driver and not NI-DAQmx
Santhosh
Soliton Technologies
(891 Views)
