PXIe-6124 Single-Ended
Hi all,
I would like to buy a data acquisition card with a sample rate of 4Ms/s and the only one I have found is this one. The problem is that the analog input is differential and my sensor is single-ended. I would like to use it with the connector block BNC-22100 because the connector of the sensors are BNC. Is there any possibility to use this card as single-ended?
Thanks a lot,
Juan Luis
(3,314 Views)
Juan Luis,
Look at pages 4-6 through 4-9 of the NI 6124/6154 User Manual.  It shows how to connect ground referenced signal sources.
Lynn
(3,297 Views)
Hello Juan Luis,
Has Lynn's response satisfied your questions about the PXIe-6124?
If you do have any further questions please reply here.
Kind Regards
Dan Vickers - Applications Engineer UK and Ireland
(3,278 Views)
Yes. Thank you for the answer.
Juan Luis
(3,273 Views)
