PXIe-6341 shows up in NI MAX but not as a DAQ
Attachment shows the issue:
The PXIe-6341 devices have both a greyed out icon and also a second icon that is not recognized as a DAQmx device.
So far I have:
Restarted computer
Restarted NI MAX
Reset configuration data in NI MAX
Removed the PCI cards (6110 and 6321)
Uninstalled all NI software and reinstalled
Updated DAQmx drivers to 9.8
System:
Windows 7 Enterprise 64-bit
Thanks in advance
Message 1 of 8
(5,524 Views)
I encountered the same problem. and the solution is to reset the NIMAX.  Open the NIMAX, select the tools->reset the configuration.
Message 2 of 8
(5,511 Views)
I have tried that, to no avail. Something is going on with the initial configuration of the device, but I don't understand what it is
Message 3 of 8
(5,497 Views)
Latest NI-DAQmx is 9.9
May be give it a try.
Message 4 of 8
(5,487 Views)
Actually, NI-DAQmx 14.1 is the latest driver. http://www.ni.com/download/ni-daqmx-14.1/4953/en/. Try reinstalling this new driver, and then restart your computer. The new driver will upgrade and overwrite your old driver without having to uninstall.
DAQmx and Windows version compatibility!: http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
Message 5 of 8
(5,475 Views)
Wrong link in the previous post. Here is the link for DAQmx and Windows compatibility: http://digital.ni.com/public.nsf/allkb/90FD507D9CACE4A886257C6D00594EA2.
Message 6 of 8
(5,471 Views)
I just wanted to give an update:
After several computers and reinstallations, my problem was was caused by the McAfee antivirus that is installed on all the computers. When it was disabled, the computer could talk properly to the 6341 cards.
Thank you everybody for all your suggestions, they were helpful in eliminating other possible problems
Message 7 of 8
(5,434 Views)
Glad to hear, thanks for the update. Best of luck.
Message 8 of 8
(5,419 Views)
