PXIe 6363 analog input Query
I have to acquire Differential(8) and NRSE(16)  analog inputs using one PXIE 6363. I am confused which type of configuration in labview program is required to achive this using NI daqmx VIs. I have attached two ways of configuration of blockdiagrams which might match to my requirement. Kindly help me which one is correct configuration
Thanks and Regards
Naveen
(5,385 Views)
Accepted by topic author rg.naveen
The bottom one in type2 appears correct.
(5,358 Views)
Thank you Dennis
(5,332 Views)
