PXIe-6713 generate pattern at 1kHz with trig from CTR0?
Hello
Is it possible to generate an AO waveform (duration 50ms) at a 1kHz rate, the1kHz trig will be generated by the ctr0 on the same card?
Thx for your answer
(195 Views)
It should be, unless the 6713 is weirdly limited compared to other devices in the 67xx family.
BTW, you'll do yourself a favor to think of and use the 1 kHz pulse train as an AO sample clock rather than a trigger.  In the DAQmx world, sample clocks and triggers serve different and distinct purposes.  Based on your description, you'll need to use it as a sample clock.
-Kevin P
(180 Views)
