Parallel port based daq and drivers
Do the following third party parallel port based daq requires driver
Message 1 of 16
(5,605 Views)
I couldn't open the PDF, would you try to give the information another way? - maybe a screenshot?  I also could not find the device using Google.  What does 'VAD' stand for? - this may help.
From what I did see, it is an interface board used for education/training.  We probably don't have an 'instant' LabVIEW driver for the board but if it comes with a DLL and some decent documentation, you should be able to get it working quickly.
Jim
Message 2 of 16
(5,561 Views)
Thank you for your effort jim
here it opening in adobe reader...
anyway i try to send it in some other way
vad is just a name it is local daq
Message 3 of 16
(5,552 Views)
Jim please try this
Message 4 of 16
(5,549 Views)
try this also
Message 5 of 16
(5,547 Views)
I could read the second attachment.  The device looks like it will be a lot of fun!!   It can be programmed in LabVIEW by using 'Port I/O VIs' - 'In Port' and 'Out Port'.  There are a lot of example programs in the document that use the functions of the device and can be easily re-written in LabVIEW.   I can probably help you get started - for now look at the In Port and Out Port VI's - Writing and reading to locations 0x378, 0x379, and 0x37A is all that is needed to control the device.
Jim
Message 6 of 16
(5,530 Views)
Thank you jim,
That means it wont require driver software to access this daq(VAD 104).Am I right........??
As u mentioned I cannot find port I/o vi in function palette(fun -connectivity). I don't have printer port in my laptop.
When I try to insert inport vi throgh labview help, it shows following error
Object not found.  Possible reason includes:
The object might exist in a different palette view.
The object might not be supported on a target in the project explorer window
The object might belong to an installed package that  now has an expired license...
But I can find inport and outport VIs in some example programme ...
Message 7 of 16
(5,518 Views)
I noticed that the vi's are not accessable in Vista or Win7 because of security concerns.  I remember using these vi's a few years ago to use the parallel port as a digital port.  I also remember having some problems after updating XP and needed a DLL in order to get it to work.
Do you plan on generating the software on the laptop and transfering to a desktop?  What OS are you planning to use?  I can do a little research and let you know what I find.
Jim
Message 8 of 16
(5,505 Views)
Hey,
I did a search on the LabVIEW board for "Parallel Port" and there was a lot of information.
The following link may be helpful for you:
http://digital.ni.com/public.nsf/websearch/B937AC4D8664E37886257206000551CB?opendocument&Submitted&&...
After you get the In Port and Out Port functions working, the rest is pretty easy.
Jim
Message 9 of 16
(5,503 Views)
HELLOW JIM HAPPY NEW YEAR
I am using labview 2010 32 bit
My os is windows 7 64 bit
I cannot find those vi s in palette, but i can find it in labview help but i cannot insert those vi from there also...
I can  find those vi in example programs also...
i have one more doubt
I have read  parallel port can transfer 8bit of data at a time.
if so,how the daq i have mentioned earlier can able to transfer data more than rated through parallel port.
(That is if i use all the available digital i/o lines and analog i/o lines simultaneously...)
Message 10 of 16
(5,496 Views)
