Passing TaskHandle between functions - ANSI C
Hi
I am trying to create a task handle and pass it to another function (in C), but, I am getting a seg fault when trying to close the task handle. What do I have wrong with the code?
Thanks in advance.
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
TaskHandle start() {
      int32 error = 0;
      TaskHandle taskHandle = 0;
      uInt8 data[1] = { 1 };
      uInt8 data_open[1] = { 1 };
      uInt8 data_close[1] = { 0 };
      char errBuff[2048] = { '\0' };
      // DAQmx Configure Code
      DAQmxErrChk(DAQmxCreateTask("", &taskHandle));
      DAQmxErrChk(DAQmxCreateDOChan(taskHandle, "Dev1/port0/line13", "", DAQmx_Val_ChanForAllLines));
      // DAQmx Start Code
      DAQmxErrChk(DAQmxStartTask(taskHandle));
      // DAQmx Write Code
      DAQmxErrChk(DAQmxWriteDigitalLines(taskHandle, 1, 1, 10.0, DAQmx_Val_GroupByChannel, data_open, NULL, NULL));
      Error: if (DAQmxFailed(error))
            DAQmxGetExtendedErrorInfo(errBuff, 2048);
      if (taskHandle != 0) {
            // DAQmx Stop Code
            DAQmxStopTask(taskHandle);
            DAQmxClearTask(taskHandle);
            printf("DAQmx Error: %s\n", errBuff);
      return taskHandle;
int stop(TaskHandle taskHandle) {
      int32 error = 0;
      printf("here1\n");
      DAQmxErrChk(DAQmxWriteDigitalLines(taskHandle, 1, 1, 10.0, DAQmx_Val_GroupByChannel, data_close, NULL, NULL));
      printf("here2\n");
            // DAQmx Stop Code
      return 0;
int main(void) {
      printf("Press enter to turn the HVPS on.\n");
      getchar();
      TaskHandle taskHandle = start();
      printf("Press enter to turn the HVPS off.\n");
      getchar();
      stop(taskHandle);
      printf("End of program, press Enter key to quit\n");
      getchar();
      return 0;
(4,672 Views)
Not sure whether it's because of you declare taskHandle only in start function? As I know, if you don't declare it in main program, you should not be able to pass it to another function.
(4,655 Views)
Hi dchaddock,
TaskHandle is an opaque pointer, and DAQmxClearTask() frees the memory that it points to, so your start() function returns a dangling pointer.
Brad
Brad Keryan
NI R&D
(4,630 Views)
Thanks. Got it sorted out.
(4,626 Views)
