Pattern I/O mode with multifunction board
I need to perform Pattern I/O digital acquisition to program my application. I have the board AT-MIO-16F-5, but I´ve been told this board is not proper for the acquisition I need. I´ve been recomended to use PCI-6534 or PCI-DIO-32HS, but these don´t have analog channels. Is there a multifunction board (analog and digital) that I can use?
Thank you very much,
Inma
(2,602 Views)
Hello;
In case you need 8 digital lines to do pattern I/O, you can use the PCI-6115 which also has Analog Inputs and Outputs.
Regards
Filipe A.
(2,602 Views)
