Performance of DAQ Tri-State and AI Read
Dear Sir,
I have a matrix array sensor,
take 2X2 for example, it looks like
    --|-|-- row 1
    --|-|-- row 2
col1 col2
There are four nodes, and need to be measured in sequence.
for example,
A B
C D
When measuring node A,  row 1 -> DO 5V, row 2 -> DO 0V, col 1 set to tri-state, col2 -> DO 0V, AI measure A
When measuring node B,  row 1 -> DO 5V, row 2 -> DO 0V, col 1 -> DO 0V, col2 set to tri-state, AI measure B
When measuring node C,  row 1 -> DO 0V, row 2 -> DO 5V, col 1 set to tri-state, col2 -> DO 0V, AI measure C
When measuring node D,  row 1 -> DO 0V, row 2 -> DO 5V, col 1 -> DO 0V, col2set to tri-state, AI measure D
Thus, for DAQ program, the process should be:
1. From all the DO channels, pick the last tri-state line, set to none tri-state, set current measure node to tri-state
2. set DO for all channels
3. AI measure current node
However, I have some questions below,
1. Could I set DO tri-state line by line? (say, set port0/line0 from port0/line0:7)
2. Could I read one of the AI channel? (say, read AI0 from AI0:7)
3. Could the loop rate higher than 10Khz?, I need to display the result in a frame base, and need the frame rate the higher the better.
4. If I need at least 16AI, 32DO and rendering enough frame rate, what is the possible hardware candidate?
Thanks in advance,
C.T.
(3,197 Views)
Dear chih-ting:
Yes, you can use the DAQmx Set Power Up States.vi to do that. As the figure shown below:
Yes, the channel can be set from the shortcut menu of the DAQmx Read.vi. Refer to the figure shown below:
If you want to define the sampling rate through the software, it will depends on the efficiency of your CPU and it will be disturbed by the application programs you use. I recommend you to use the hardware clock to set the sampling rate instead.
It also depends on your budget. I list some of the devices fit the requirement below:
NI 6323, NI 6343, NI 6353, NI 6363, NI 6368, NI 6289, NI 6284, NI 6259, NI 6254, NI 6229, NI 6224...and so on.
Hope this help.
NI Applications Engineer
(3,185 Views)
