Physical Channels for USB 6009 missing
I have just installed the USB 6009 DAQ and NiDAQms Base 1.4. MAX says, that the device is working properly, but if I try to create a task or a virtual channel, no physical channels are selectable and the device is not recognized there. The same happens in LabView, when I try to use the DAQ Assistant.
(3,067 Views)
Hi sdczyk-
If you are using NI-DAQmx Base then the device will not be listed in MAX except under the USB device heading, so I'm not sure how you are verifying the operation in MAX.  In order to use your USB-6009 as an NI-DAQmx device in MAX or LabVIEW with the DAQ Assistant you will need to install and use NI-DAQmx 7.5.
Instructions for converting your USB-6009 for use with NI-DAQmx 7.5 are available in this KB.
Hopefully this helps-
Tom W
(3,054 Views)
