Physical channel change with DAQmx 8.7 upgrade
  I am currently using a DAQPad 6015, it is the 64 pin mass screw terminal version.  I just recently upgraded my DAQmx from 7.3.1 to 8.7 with that it upgraded my Automation Explorer to Version 4.4 I was either at 3.1 or 4.0.  I noticed when I was using the DAQ wizard to set up my channels it looked like the physically changed on the terminal block.  Is this right???  I normally use Differential Channels, and would normally use Pin CH1(1,2)     CH1(4,5)
CH2(7,8)          CH3 (11,12)         CH4(17,18)     CH5 (20,21)      CH6 (23,24)          CH7 (26,27).   I am seeing a completely different configuration.  Any knowledge of this??
Chris
(2,707 Views)
OKAY......nevermind brainfart on my half.....the channels didn't change I had them organized differently in the VI and forgot I did that.......
(2,700 Views)
