Play .wav file through DAQ o/p channel
I want to play a *.wav file through AO channel of USB 6008 then AO is connected to the speaker. I found the NI supported VI here but i get error when i extract the file. I appreciate someone can help me to troubleshoot this vi?
Venkates
(3,617 Views)
Looking at the snapshot it seems that there are number of broken wires which is not allowing you to run the code. One way is to logically connect the wires and/or check that you have the required drivers installed because if they are absent then also the wires could be broken. You can share the source of the code maybe we can connect the wires for you and share it with you again.
Thanks.
cheers.!
(3,593 Views)
I understand the broken wires is also a bug but this is not my actual problem, when i extract the file it asks ....\instr.lib\National Instruments Instrument Simulator\Public\Waveform Generator\Configure then selected this file in the LabVIEW sw folders.
Attached the file and now someone can see the actual problem.
venkateswaran
(3,577 Views)
The example you linked :
Hardware Group: Multifunction DAQ (MIO)
Driver: Traditional NI-DAQ (Legacy) 6.9.2
I'm not sure but I think the USB 6008 only supports the DAQmx driver.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,556 Views)
