Please ADVICE.
Hello.
I have DAQCard-1200 and LabVIEW 5.0.1f.
I should measure resistance in range 100 - 1000 kilohms.
Can I do it? Please advice me. Can I use +5V from pin 49 in my DAQCard for
this task?
Is circuit (see attachment) will be work?
Ohm's law.
Thank you.
Vadim Gnatkovsky.
[Attachment circuit.bmp, see below]
[See first answer for additional information]
(3,693 Views)
[Attachment(s) for question]
(3,693 Views)
Vadim
That circuit will not work as you have drawn it. It will work if you rearrange the circuit like the attached 'circuit.bmp' and use
these equations.
I[R] = I[1k] = (5V-U2)/1k
R = I[R] x U2
Also note that you cannot always guarantee the supply voltage to be exactly 5V or even stay the same under load conditions. It may
pay to set aside a channel to measure the 5V supply. Of course this really depends on the accuracy and repeatablility of the
measurement.
Tim Streeter
Vadim Gnatkovsky wrote:
> Hello.
> this task?
> Ohm's l
aw.
> Thank you.
> Vadim Gnatkovsky.
> circuit.bmp Type: Bitmap Image (image/bmp)
> Encoding: x-uuencode
(3,693 Views)
