Please Help with SCXI 1125 calibration
Please Help me
Does anyone have some LabView or VB6.0 Program that Peform the SCX 1125 Calibration?
At this time we have a test machine that uses the SCX 1125 with the PXI 6131E and the readings are some times in ramdom mode or fixed on all channels (only using 3 channels)
We are using the Traditional NI-DAQ 6.9.3 with, MAX 3.0 and  LabView 7Express
Sorry I was working all the night by trying to find out this problem and I need some help with this.
I read the SCX 1125 Calibrarion Procedure but i have short time.
Please any help will be appreciated !!
Thank you
(2,997 Views)
You can Calibrate SCXI Modules with NI-DAQmx (you must update the daqmx version), another method is using Calibration Executive, this method is the easiest but you need to buy the software (if you don´t have it yet). I attach some links with the procedure to calibrate your module. Let me know if you have any question.
Usted puede Calibrar los módulos SCXI con NI – DAQmx (Tienes que actualizar la versión), otro método que tienes es usar el software Calibration Executive, este método sería el más sencillo pero tú necesitas comprar el software (en caso de no tenerlo). Te agrego algunos links con el procedimiento para llevar a cabo la calibración. Hazme saber si tienes alguna duda al respecto.
http://digital.ni.com/public.nsf/allkb/DAC4C20C9AE291A4862570E5006B0F3C?OpenDocument
SCXI Calibration Tutorial: External Calibration with DAQmx 8.0 and Later
http://zone.ni.com/devzone/cda/tut/p/id/4845
NI Calibration Executive
http://sine.ni.com/nips/cds/view/p/lang/es/nid/12547
NI-DAQmx 8.6 - Windows 2000/Vista x64/Vista x86/XP
http://joule.ni.com/nidu/cds/view/p/id/833/lang/es
CALIBRATION PROCEDURE
http://www.ni.com/pdf/manuals/370271a.pdf
Coamin Cruz
Ae México
(2,985 Views)
