Power Output of NI 9234 DAQ Card on NI cDAQ-9174 Chassis
Hey Guys,
I'm trying to find out the current/power output of the NI 9234 DAQ card in each of its 04 channels. I wish to connect GRAS 40PP CCP Free-field QC Microphone to it using an analog BNC connector cable. The microphone requires a 4 mA current and DC voltage input. I'm unable to receive any signal in the SignalExpress 2015 when I connect it.
Can anyone help me with this?
(2,394 Views)
You need to enable IEPE voltage in the settings when you configure your 9234.
After that you should be able to supply enough power to the microphone through BNC cable.
(2,356 Views)
