Power Supply Pin Polarity on USB-6363
Hi
I am trying to power the USB-6363 with an external power supply but the pin labeling on the back of the DAQ is very confusing. One of the pins is labeled "C" and the other "V". Which one of the two is "Ground"?
Could not find the information in any document nor by opening the DAQ and looking at the PCB board...
Thanks!
(2,810 Views)
Accepted by topic author FrankRWC
Just got the information from an NI rep:
"C" = Common = Ground = Negative terminal
"V" = Positive terminal
(2,736 Views)
