Power VI
Hello everyone,
I am working on NI USB 6009 interfaced with Labview. I have to do just simple task of obtaining Power values including power factor.
I am giving 6v rms [aslo tried with 10vrm, 8vrms] to NI USB 6009 in ai1 for voltage waverform in labview and also using ACS712 in pin number ai4 for current waveform. As ACS712 gives output in the form of voltage so I am acquiring voltage in DAQ [configuration given in picture].
Now the problem is that when I connect Power VI and read values I am not getting values which I want. I get wrong power factor, wrong active and reactive power etc. Note the load is 1kw heater.
Looking for your responses.
(1,511 Views)
We cannot debug pictures, especially if they contain express VIs and dynamic data. I don't recognize the subVI that does the calculations. Is that from some toolkit? Do you have a link to the documentation?
Please attach your VI.
(1,472 Views)
Please find VI.
(1,457 Views)
I still cannot view the properties of your express VI and I don't have the "power" subVI, which seems to be from a toolkit.
What kind of data is contained in the dynamic data wire? We cannot tell!
(1,437 Views)
