Prefix_InitWithOptions?
I currently want to use the C function
Prefix_InitWithOptions(...); //where prefix is the instrument prefix
The instrument I am using associating with this is the Lecroy Digitizer PXD1022. I am wondering how can I get the instrument prefix for this device? Thanks!
(3,298 Views)
The prefix is typically a combination of an abbreviation of the vendor name and the model number.  If you execute the *idn? command on  your instrument, it will often say the vendor followed by the prefix.  Does this work with your instrument?  If not, let me know and I will try to find an alternate method for you.  Have a great day!
Chris R.
Chris R.
(3,280 Views)
Hi Chris,
Actually I found the c functions when I installed the drivers for the digitizer. They were alreayd included in the software with the correct prefix in front of the functions.
Thank you for your time anyway Chris!
-Mike
(3,275 Views)
