Pressure Sensor for -14.7psi to 5000psi NI 9233
Hello
I am looking for a pressure sensor that is ideally self-contained (ICP style) with a BNC connection and no additional power supply.
The response time would ideally be << 1 ms and the ability to measure the "DC" pressure as well as the transients would be essential.
Can anybody recommend a sensor that would suit the Multifunction DAQ that has an absolute pressure range of about 5000psi?
(3,493 Views)
One problem might be that the current version of the 9233 is AC coupled so that the response doesn't go to DC.  I've heard "rumors" of new products/versions that might have DC coupling but nothing firm yet.
(3,487 Views)
http://digital.ni.com/public.nsf/allkb/3B1DD690A53EBC098625706C004A4FF3
(3,486 Views)
Thanks for the helpful reminder.
I use the 9233 with the S&V Toolkit and I appreciate the USB convenience of the M-series.
The drop is -3dB at 0.5 Hz which is no problem in noise measurement.
I wonder if the NI 9239 4-Channel, 24-Bit Analog Input Module would be a suitable module.
It has DC coupling and a good sampling rate. Does anybody on the foruma have experience with it and pressure sensors?
(3,464 Views)
