Pressure regulator control with PCI 6024E Daq Card
Hi all,
I want to control a pressure regulator with PCI 6024E Daq Card.
Pressure regulator properties.
1. +24 V DC and power GND
2. Set input (0..10 V) and setGND
and 0..10 Bars work with pressure value.
i want to ask , my pressure value is 0-7 Bars so how can use a vi for change Daq card output voltage value is match. And which toolbox can i use? sample PID? and how..
(3,054 Views)
Hi Delidolu,
Thank you for posting to the NI forums.  I’m a little unclear about some aspects of your application.  Just to be sure, the PCI-6024E has an analog input range +/-10 V.  So this device will not be able to measure a 24 V signal, and this may actually damage the device.
Otherwise, I don’t believe that you’ll need any specialized toolkits for this application – you should be fine with the DAQmx driver, available for free download from our website.
DAQmx Download
You can convert the voltage signal into pressure units using a custom scale for your task.  This can be done in Measurement & Automation Explorer (MAX) when you create your task, or programmatically.  There is a nice Knowledge Base entry that explains how to do this.
Programmatically Create a Custom Scale in DAQmx
I hope this helps.  Please post back if you have further questions.
Ed W.
Message Edited by Ed W on 04-05-2007 05:56 PM
(3,046 Views)
