Prevent apllication crash when DAQmx driver missing
Hello
I have written a c# program with the option to measure data via USB-6215 and DAQmx driver when available. (NationalInstruments.DAQmx.dll)
Problem is that when no DAQmx driver is installed the program doesn't start.
Is there a simple way to prevent this.  I am not so familiar with dynamic dll load. Has someone an example?
Thanks Jan
(606 Views)
You need to have a startup application that checks for the dependencies and, once satisfied, calls the main application; thereby, you can avoid the crash.
Santhosh
Soliton Technologies
(594 Views)
