Problem compiling and linking mathlibrary and nidaqmxbase under SuSe Linux 9.2
Hi.
I've stumbled into an error when trying to use the math library toghether with nidaqmxbase library.
The compile works well, the following is an output of my compilation.
if gcc -DHAVE_CONFIG_H -I. -I. -I..    -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include   -ggdb -g -O2 -MT nid-counter.o -MD -MP -MF ".deps/nid-counter.Tpo" -c -o nid-counter.o `test -f 'counter.c' || echo './'`counter.c; \
then mv -f ".deps/nid-counter.Tpo" ".deps/nid-counter.Po"; else rm -f ".deps/nid-counter.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I..    -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include   -ggdb -g -O2 -MT nid-dio.o -MD -MP -MF ".deps/nid-dio.Tpo" -c -o nid-dio.o `test -f 'dio.c' || echo './'`dio.c; \
then mv -f ".deps/nid-dio.Tpo" ".deps/nid-dio.Po"; else rm -f ".deps/nid-dio.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I..    -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include   -ggdb -g -O2 -MT nid-nid.o -MD -MP -MF ".deps/nid-nid.Tpo" -c -o nid-nid.o `test -f 'nid.c' || echo './'`nid.c; \
then mv -f ".deps/nid-nid.Tpo" ".deps/nid-nid.Po"; else rm -f ".deps/nid-nid.Tpo"; exit 1; fi
if gcc -DHAVE_CONFIG_H -I. -I. -I..    -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib/glib-2.0/include   -ggdb -g -O2 -MT nid-input.o -MD -MP -MF ".deps/nid-input.Tpo" -c -o nid-input.o `test -f 'input.c' || echo './'`input.c; \
then mv -f ".deps/nid-input.Tpo" ".deps/nid-input.Po"; else rm -f ".deps/nid-input.Tpo"; exit 1; fi
/bin/sh ../libtool --mode=link --tag=CC gcc  -g -O2   -o nid -L/opt/gnome/lib -lglib-2.0   -lm nid-counter.o nid-dio.o nid-nid.o nid-input.o  -lnidaqmxbase
mkdir .libs
gcc -g -O2 -o nid nid-counter.o nid-dio.o nid-nid.o nid-input.o  -L/opt/gnome/lib /opt/gnome/lib/libglib-2.0.so -lm -lnidaqmxbase
The problem arise when i try to run the application, I get:
./nid
ERROR! The LabVIEW RunTime Engine failed to initialize correctly.
This is usually caused by linking applications incorrectly.
Please see the AppLibs/README.shlibs file in the LabVIEW directory for
instructions on building programs using LabVIEW-built shared libraries.
LabVIEW caught fatal signal
 - Received SIGSEGV
Reason: address not mapped to object
Attempt to reference address: 0x4
Segmentation fault
If i dont link the mathlibrary then everything works. The problem is that i need the mathlibrary for my application
Any suggestion where the problem is ?
regards /josef
(3,111 Views)
Hello Joseph!
Is your problem still an issue or is it solved?
Ashwani S.
National Instruments Sweden
(3,091 Views)
I've solved it. See the other thread i posted on this forum.
thanks anyway..
cheers /josef
(3,088 Views)
