Problem setting up a digital pause trigger on a PCI-6133
I am trying to set up a digital pause trigger using DAQmxSetDigLvlPauseTrigSrc(), etc. and it all works fine with a PCIe-6323 but it does not seem to work with a PCI-6133.
The setup calls return no errors, but when I actually start the task, I get "Error code could not be found. Reinstalling the driver might fix the issue. Otherwise, contact National Instruments technical support."
I'm using the latest NI-DAQmx 20.7 and when I look up the PCI-6133 in cdaqmxsupp.chm it appears that these calls should be supported by this card.
Thanks in advance for any advice.
Message 1 of 1
(1,142 Views)
