Problem to install a chassis SCXI 1000DC with a modul SCXI1112
So I install a chassis SCXI 1000DC normally but NI Max don t detect the modul SCXI1112 and SCXI 1530.So the test of the chassis is wrong.
Moreover,is it normal that all the light on the SCXI 1112 modul are red.
Thanks in advance.
(2,413 Views)
Mous,
The first step is to make sure that the NI-DAQ driver is installed properly and that your DAQ board (6025E) is working properly.
Then, refer to page 2-6 and 2-7 of the SCXI 1112 User Manual. It gives some troubleshooting help for the error you are receiving.
http://www.ni.com/pdf/manuals/322476a. pdf.
You may also want to try installing the 2 modules separately and install them in different slots to rule out which module or slot is causing a problem.
Hope this helps. Have a great day
(2,413 Views)
