Problem using counter input while using digitial output
Hi there.
I am using a USB-6251 and want to measure a frequency using one counter while generating a digital wavefor on Port0.
Each task exectutes nicely on it's own, but when I try to run both tasks together, I get the following error message:
NationalInstruments.DAQmx.DaqException
Message: Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Property: NationalInstruments.DAQmx.CIChannel.CounterTimebaseActiveEdge
Source Device: Dev1
Source Terminal: 80MHzTimebase
Destination Device: Dev1
Destination Terminal: Ctr0Source
Required Resources in Use by
Task Name: TriggeredPinChange-Output
Source Device: Dev1
Source Terminal: 20MHzTimebase
Destination Terminal: do/SampleClock
What am I doing wrong?
Message 1 of 1
(3,040 Views)
