Problem while generating sinewave on a PCI 6722 with MAX
Hi
I'm using a PCI 6722 card, with a BNC 2110 bloc. With MAX, I try to generate a sinewave and visualize with a scope, but the signal seems to be overranged when the command is over 0.4V. I've got a second PCI 6722, and it gives exactly the same problem.
I'm using MAX 4.1.0.3001 and DAXmx 8.3 on a XP SP2 system.
Regards
(4,013 Views)
What could you said by "the signal seems to be overranged" ?
I think you go on a test panel under MAX, and set the AO0 to generate a sinus a 1V.
On the field for maximum and minimum value ther is +10V & -10V, no ?
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,998 Views)
Hi
I've got another problem : when I try to test each AO, there's only one (AO4) which works (I can see the sinewave, although it's clipped), all the others give only noise. It's exactly the same problem with another 6722, or with another BNC 2110. So that we can say that AO0 didn't work at all...
I'ts probably me who didn't connect correctly those devices...
Regards
PS : are you from the french support team ?
(3,991 Views)
Have you configured correctly the BNC-2110 ?
On this one you can set a thermocouple for measure temperature on Ch0.
On MAX, when you configure the property of the board, i think you have choose an BNC-2110, isn't it ?
All of the devices in the 672x series of analog output devices incorrectly list the BNC-2111 as an accessory option. This is a typing error. To use your PCI-6722 analog output device with the BNC-2110, select the BNC-2111 as the accessory. This properly configures your device to work with the BNC-2110.
http://digital.ni.com/public.nsf/websearch/5E5DFEF10C256A1A86256D7F0063CD92?OpenDocument
And after you can have this connection :
BNC-2111 Channel AO Channel
AO 0 AO 0
AO 1 AO 1
AI 7 AO 2
AI 6 AO 3
AI 5 AO 4
AI 4 AO 5
AI 3 AO 6
AI 2 AO 7
http://digital.ni.com/public.nsf/allkb/BD69B93090555F56862572AB0056E7F8?OpenDocument
It's more easy to use a scb-68 or scb-68, because we haven't this problem.
Yes i'm from the french support team.
Christophe S.
(3,983 Views)
Hi
I don't have the BNC-2111 available in the property menu as accesory, I've got only :
None
BNC-2110
BNC-2120
CP-68LP
CP-68LPR
SCB-68
TBX-68
Perhaps did I make a mistake during the installation ? I just plugged the board and tried it with MAX, I did nothing else. I tried to connect the board directly on a PCI-6132, and of course it works fine. And for this other board, I've got
the BNC-2111 available in the property menu.
Regards
(3,957 Views)
Which version of the BNC-2110 do you use ?
You can found the revision of the bottom, ther is the letter on the part number.
Revisions D and higher of the BNC-2110 are changed to include mappings for the 671x boards. The modifications include an overlay with the right labels for AI (analog input) and AO (analog output), and changing the position of AO channels 0 and 1 so that they coincide with all other AO channels.
All previous revisions of the BNC-2110 are compatible with the 671X boards, but with the following mapping:
 671X BNC-2110
AO-0 DAC 0 Out
AO-1 DAC 1 Out
AO-2 ACH7
AO-3 ACH6
AO-4 ACH5
AO-5 ACH4
AO-6 ACH3
AO-7 ACH2
http://digital.ni.com/public.nsf/allkb/BD264E586AE4B6518625689500835156?OpenDocument
Message Edité par Christophe S. le 01-14-2008 11:27 AM
Christophe S.
(3,950 Views)
Hi
It's the F revision...
Regards
(3,945 Views)
