Problem with NIDAQmx C API by setting minimum and maximum values for a channel.
I am using NIDAQmx C API provided by NI to access analog inputs. I wrote some functions to create analog input channel and to set minimum and maximum values for a particular channel.
For this I used the following function to create analog channel.
DAQmxCreateAIVoltageChan (taskHandle, "Dev1/0", "", DAQmx_Val_Diff, -10, 10, DAQmx_Val_Volts ,NULL);
and I used this function to set some different min and max voltages for the above created channel.
DAQmxSetAIMin(taskHandle, "Dev1/0", -5);
DAQmxSetAIMax(taskHandle, "Dev1/0", 5);
When I called these functions it is not rising any exceptions. It is returning "0", this means function is successfully executed.
Then I tried with DAQmxGetAIMin, DAQmxGetAIMax functions to know the current min and max voltages.
I found min and max voltages are -10 and 10. But I set these values as -5 and 5.
Please guide me is there any need to use any other functions to set the new min and max voltages.
(3,730 Views)
hi amlu,
I hope these links will help you:
Using Min/Max or High/Low to Set DAQmx Channel Gain
The DAQmx Gain Property Doesn't Modify My DAQ Device Channel Gain Value [broken link removed]
Greets!
(3,716 Views)
Thank you for your reply.
Where can i get the gain information of PCI 6251.
(3,712 Views)
Try page 4 of the brochure at:
http://www.ni.com/pdf/products/us/044063301101dlr.pdf
You can also try setting the max value to something lower than the lowest gain that NI uses and see what is acturally set and try setting it slightly higher than the value returned, try again to set it slightly higher, etc. until you get all the possible max values.
Message Edited by duncan carter on 06-13-2005 03:17 PM
(3,705 Views)
Shouldn't this be:
DAQmxCreateAIVoltageChan (taskHandle, "Dev1/ai0", "0", DAQmx_Val_Diff, -10, 10, DAQmx_Val_Volts, NULL);
DAQmxSetAIMin(taskHandle, "0", -5);
DAQmxSetAIMax(taskHandle, "0", 5);
(3,685 Views)
