Problem with continuous measurment in MAX using DAQCard-3036E and BNC-2120
when testing the 3036E PCI within MAX for Analog Input the "continuous" and the "n samples" measurement does not work. The "On Demand" measurement works fine. Within Signal Express and LabVIEW (Express DAQ-VI) it is the same plus a "timeout" error.
On an other (much older) PC the measurement works.
Please find attached the MAX configuration reports for both systems.
I hope this description is sufficiant.
With kind regards
Andreas
(3,158 Views)
I tested the DAQ with two PCs, and the problem seems to be located in the Operating system. The continuous measurement works with the Windows 2000 (SP4) PCs and does not work on Windows XP (SP3).
Is there a known problem with continuous DAQ under Windows XP?
(3,119 Views)
Hi Andreas,
what is the number of the timeout error?
Could you please post a small LabVIEW example with the Express VI?
Kind regards
Carsten
(3,055 Views)
