Problem with my Device configuration
I have configured my device on the DAQ wizard. It still shows and error 10401 while I run my program.
I need technical assistance in this aspect
(2,733 Views)
The best way to get this error is to accidentally use the wrong device number in your program. Double check what the device number is for your card inside MAX under "Devices and Interfaces," Then make sure this is the same number you are using in your program. I hope this helps!
Russell
(2,733 Views)
That was it!!!
Thanks.
(2,733 Views)
