Problem with reading a buffer
My question is a little complex, so I join an illustration : I want to make an acquisition of 256S @ 20KHz every time I have an external trigger, and read the buffer with LabView every 5 triggers (so, I read 1280 Samples).
Do you have any solution ?
Thanks for your help !
Mathieu
(3,062 Views)
Hello Math,
I have make an example with functionality that you want. On this example, you can use trigger for each measure, and i have use a shift register for display data only after 5 trigger.
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(3,039 Views)
