Problema : LabView´s Memory Corrupted
During a temperature measurement session, I got the the following message and my application stopped:
"An exception occured within the external code
called by a Call Library Node. This may have corrupted
Lab View´s memory. You should save any work to
a new location and restart LabView. VI "xyz.vi" was
stopped at node 0x2380 of subVI "AI Single Scan (single-point waveform).vi"
Why did it happen? How can I fix this problem?
(2,690 Views)
It sounds like something strange happened in a NI-DAQ VI. If you keep getting the error I would suggest re-installing NI-DAQ and if that does not help re-install both LabVIEW and NI-DAQ.
(2,690 Views)
