Problems installing Daqmx 8.7.1 with Vista
I'm trying to install DaqMx 8.7.2 in my computer running Windows Vista.
I want to install USB 6501.
I have installed in my computer LabVIew 7.1, 8.5.1, 8.6 and Beta 2009.
When I try to install Daqmx, the instalation program shows the following picture.
Is there anything I'm doing wrong ?
I'm using the Device Drivers DVD from LabVIEW 8.6.
Ricardo Kiu Otake
RKO Sistemas
RKO
(4,280 Views)
Hi Ricardo,
The error says to uninstall the older vrsions of thelisted drivers before install this new version. Do you try it?
You can try the newer version of NI-DAQmx, the NI-DAQmx 8.9.
http://joule.ni.com/nidu/cds/view/p/id/1216/lang/en
 Also LabIEW 7.1 is not supported by Windows Vista. Vista support started at LabVIEW 8.2.1.
Abel
National Instruments Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(4,250 Views)
Accepted by topic author ROtake
Oi abel
Eu já tinha resolvido o problema desinstalando as versões anteriores de Daq que não eram compatíveis com o Windows Vista. Também já baixei  a versao mais nova do DaqMx.
Obrigado
Ricardo Kiu Otake
RKO Sistemas
RKO
(4,244 Views)
Hi
I have the same problem when instell  the DAQmx 8.9, my OS is vista, please help me .
(4,098 Views)
Ricardo solve de problem removing versions that are incompatible with Vista and after installing the last version of DAQmx.
Abel
NI Brazil
Abel Souza
(4,094 Views)
