Problems to measure a signal with 10kHz frequenz
i want to measure a signal at 10khz frequenz.
My problem is that from 100Hz above i dont get a clear Signal.
(2,516 Views)
Daniel,
Could you provide more information about your task.
- What type of signal is it (sine, square wave, etc.)?
- What hardware are you using to measure the signal?
- What type of input are you using (analog in, digital in, counter)?
- How are you performing the measurement? What functions are you using? What development environment (LabVIEW, C, etc.) are you using? Can you attach an example of your code?
Christian L
NI Consulting Services
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(2,516 Views)
