Problems when using two USB-6008 at the same time
Hi
No I didn't find either when I was looking for any information about my problem. No big deal but I'm guessing that this is a problem for many others who have used the Base driver earlier. My suggestion is to make a FAQ question about this problem so that it can be quickly found at the website. As I said otherwise the driver seems to be working properly and without any problems.
Regards
Daniel Holmqvist
Message 11 of 13
(1,169 Views)
If you have used a USB-6008 or USB-6009 with N-DAQmx Base on the same computer that you install N-DAQmx 7.5, the device will still be associated with NI-DAQmx Base, as you all have found out.  You also found both of the options for how to re-associate the device with the appropriate driver.  Below are some knowledge bases that discuss this re-association idea.
KB:3NE7GJMY
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIRDCA4&l=en-US
Message Edited by Jeremy C on 07-27-2005 11:06 AM
Message 12 of 13
(1,154 Views)
Dear Daniel,
In my project currently i am use 6 USB 6008.and i have not any problem related to this DAQ.
Only one care u taken about data logging is u can use sequence logic instand of parallel process.
If uwant any help u can contact me on my yahoo id:jatin121in@yahoo.co.in.
regards,
Jatin Bhatt
Message 13 of 13
(1,071 Views)
