Program mile second timer
Dear Sir
     I would like to program a Millie second timer mean I couldn't find the option to install or program a Millie second timer. Do u have sir any tip for me about how can I program or represent a Millie second time. am measuring the fall and rise time of an analoge(block) signal and i need to subtract the two times I measured to have the duration of the block.the change is so fast that can happened in Millie seconds so with out timer that can hold or represent the Millie seconds i will not be able to see the difference.
thank u for ur concern Sir.
HAG Dabbagh
Student Electrical engineering TUDelft.
(3,411 Views)
Hi Dabbagh,
What hardware do you have? And what software? And what kind of signal? What is the level?
Bas
(3,394 Views)
