Programming NI-DAQmx in Visual C++ .NET 2003
I have problems in using NI-DAQmx in VC+.NET 2003. I have read the KB article https://www.ni.com/en/support/documentation/supplemental/18/archived--programming-traditional-ni-daq... and I followed the steps in the last part for NI-DAQmx. However, when I compiled my project, this error still came:
error LNK2019: unresolved external symbol _DAQmxCreateTask@8 referenced in function "public: long __thiscall CDAQmxfunc::Configure_AcqIntClkAnlgStart(char const * const,double,double,unsigned long,double,unsigned long *,unsigned long *)" (?Configure_AcqIntClkAnlgStart@CDAQmxfunc@@QAEJQBDNNKNPAK1@Z)
which means the lib files still couldn't be found. After I added the NIDAQmx.lib in my project, this problem is solved.  Did I make the right move? Also, when I referred to the DAQmx ANSI C samples for NI-DAQmx, I saw only this header file NIDAQmx.h is included. Is it the same in VC++.NET?
Thank you very much.
David
(4,800 Views)
Hi David,
You did the correct thing by adding the NIDAQmx.lib file to your project. Also, the NIDAQmx.h file is the same.
Hal L.
(4,785 Views)
I have a similar problem in VS 2008.  I can compile the example code (VC_ContFreq_IntClk_SCXI1126) no problem from Visual Studio 2008.
However, when I create my own project in visual studio with the same #includes i get the same errors:
Compiling...
DTRTestNov2010.c
Linking...
DTRTestNov2010.obj: error LNK2019: unresoloved external symbol _DAQmxClearTask@4 reference in function _main
DTRTestNov2010.obj: error LNK2019: unresoloved external symbol _DAQmxStopTask@4 reference in function _main
and so on... for all other function calls I made.
i am not a pro at c-programming.  Am I supposed to setup a 'linker' somehow?
Thanks!
Sean
Here is my c-code (which operates in matlab typically, but I think is spawning a memory leak, so i'd like to test it in native C)
#include <stdio.h>
#include <NIDAQmx.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
int main(void)
int32       error=0;
TaskHandle  masterTaskHandle=0;
TaskHandle  slaveTaskHandle=0;
int32       read;
int32 fs=30000;
int32 samplesPerLoop=30000;
int32 channels=4;
int32 arrayLength;
float64     data[30000];
char        errBuff[2048]={'\0'};
arrayLength  = samplesPerLoop * channels;
// DAQmx Configure Code
DAQmxErrChk (DAQmxCreateTask("",&masterTaskHandle));
DAQmxErrChk (DAQmxCreateTask("",&slaveTaskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(masterTaskHandle,"Dev1/ai0:3","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCreateAIVoltageChan(slaveTaskHandle,"Dev1/ai0:3","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(masterTaskHandle,"",fs,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,samplesPerLoop));
DAQmxErrChk (DAQmxCfgSampClkTiming(slaveTaskHandle,"",fs,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,samplesPerLoop));
DAQmxErrChk (DAQmxCfgInputBuffer(masterTaskHandle,samplesPerLoop*2));
DAQmxErrChk (DAQmxCfgInputBuffer(slaveTaskHandle,samplesPerLoop*2));
DAQmxErrChk (DAQmxExportSignal(masterTaskHandle,DAQmx_Val_StartTrigger,"RTSI0"));
DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(slaveTaskHandle,"RTSI0",DAQmx_Val_Rising));
DAQmxErrChk (DAQmxSetExportedSampClkTimebaseOutputTerm(masterTaskHandle,"/Dev1/RTSI8"));
DAQmxErrChk (DAQmxSetSampClkTimebaseSrc(slaveTaskHandle,"RTSI8"));
DAQmxErrChk (DAQmxSetExportedSyncPulseEventOutputTerm(masterTaskHandle,"/Dev1/RTSI9"));
DAQmxErrChk (DAQmxSetSyncPulseSrc(slaveTaskHandle,"RTSI9"));
// DAQmx Start Code
DAQmxErrChk (DAQmxStartTask(slaveTaskHandle));
DAQmxErrChk (DAQmxStartTask(masterTaskHandle));
// DAQmx Read Code
DAQmxErrChk (DAQmxReadAnalogF64(masterTaskHandle,samplesPerLoop,5.0,DAQmx_Val_GroupByChannel,data,samplesPerLoop,&read,NULL));
DAQmxErrChk (DAQmxReadAnalogF64(slaveTaskHandle,samplesPerLoop,5.0,DAQmx_Val_GroupByChannel,data,samplesPerLoop,&read,NULL));
printf("Acquired %d points\n",read);
Error:
if( DAQmxFailed(error) )
DAQmxGetExtendedErrorInfo(errBuff,2048);
if( masterTaskHandle!=0 )  {
// DAQmx Stop Code
DAQmxStopTask(slaveTaskHandle);
DAQmxStopTask(masterTaskHandle);
DAQmxClearTask(slaveTaskHandle);
DAQmxClearTask(masterTaskHandle);
printf("DAQmx Error: %s\n",errBuff);
printf("End of program, press Enter key to quit\n");
getchar();
return 0;
(4,396 Views)
Hi Sean,
Yes, you must tell the linker where nidaqmx.lib is located. Here are a couple of KBs explaining how to do this:
When Compiling a DAQmx ANSI C Example in Visual C++ I Receive Link Errors
Location of ANSI C NI-DAQmx Shipping Examples and DAQmx Library File for Windows
Brad
Brad Keryan
NI R&D
(4,384 Views)
