Programming the PCI-6013 with QBasic
I have been asked to purchase a number of DAQ cards that need to be able to be fully programmed in qbasic believe it or not, and I have been unable to determine from the NI website if the PCI-6013 could be programmed in such a manner. This will require full access to all onboard data and configuration registers etc etc.
If anyone could provide a simple yes or no answer I would be most obliged.
(2,660 Views)
Simple answer = NO.
The 6013 board is supported in our NI-DAQ 6.9.3 and later drivers. These drivers DO NOT offer support for QBasic. If you really want to use the 6013 boards, I would recommend programming in C or Visual Basic.
Bill B
(2,659 Views)
