Pulse Train Ctr Configuration
I am updating a legacy application using LabView 5.1 and the DAQCard-500.  I have NI-DAQ ver 6.9.3 installed.  I installed NI-DAQ after LabView.  I have no other versions of LabView installed on this machine.  I have confirmed that I am using the correct device number.
I am using the generate pulse train.vi and get the following error message:
Error -10403 occurred at CTR Group Config.
Possible Reasons:
NI-DAQ LV: The specified device does not support the requested action (the driver recognizes the device, but
the acion is inappropriate for the device).
Looking a bit deeper I see that CTR Group Config is called in a subvi of Generate Pulse Train.vi but I do not understand why I would get the error message on the presumption that the Generate Pulse Train.vi is matched to the DAQCard-500.
Where might I be going wrong?
Is there a definitive way to know if I am using the correct .vi for the DAQCard-500?
How could I troubleshoot this further?
Thanks in advance,
Bernie
(3,497 Views)
Figured it out, this vi does not support the DAQCard-500.
(3,491 Views)
Hi Bernie,
You may find helpful information regarding VIs that will work with your device in this forum discussion.
Luke
(3,465 Views)
