PyDAQmx and USB-6000/USB-TC01 Thermocouple Device
None of that has anything that resembles the little bit of PyDAQmx that I saw. Study the c function prototypes as noted.
Message 11 of 27
(4,041 Views)
@Yakav wrote:
Either help contribute, or don't reply. I'm not looking for passive-agressive answers - this goes to nyc
You are the person who chose to go down this path of using Open Source software.
You are the person who needs to do the work.
It seems you want the answers handed to you on a platter.
Do some WORK!
Message 12 of 27
(4,035 Views)
Nyc,
Please leave - you are obviously a troll and unwilling to promote meaningful dialogue. Others have actually guided me towards a direction, while you on the other hand have been inconsiderate and ill-mannered. Take your unnecessary banter elsewhere.
Message 13 of 27
(4,029 Views)
@Yakav wrote:
Nyc,
You were guided to the PyDAQmx website eons ago, and yet you choose to ignore it.
And kept coming back here for goodness know what reason?
Engineering is hard. If it was easy, people could just keep asking questions on message boards.
Message 14 of 27
(4,023 Views)
If you attempted to read my comment earlier, you would have seen that I did read the PyDAQmx documentation and source code. This dead-end in information led me to asking if others have attempted a similar path (which obviously you haven't). I'm not interested in your lecturing, I could care less.
Here's a question, what are the message boards for? I've browsed around the forums looking for a similar question but no luck. So, am I suppose to go off leads with no lead?
Message 15 of 27
(4,014 Views)
How exactly is it "dead end"????
And, again, you chose to use PyDAQmx. No one forced you to use it.
No documentation is due to *your* decision to use the software.
Message 16 of 27
(4,007 Views)
I am forced to use PyDAQmx due to the circumstances of my company - please, take the time to read my previous comments (this is already explained). You obviously have trouble understanding my goals. Are you mentally handicapped? Please go entertain others that might be interested in a clown
Message 17 of 27
(4,004 Views)
And again, your company gets what it "paid" for.
The documentation is there on the PyDAQmx webpage.
And again, what makes it "dead end"?
Message 18 of 27
(4,002 Views)
I stumbled upon this thread after having the same task to do like you, which is reading out a NI USB TC01 via Python. It's probably a bit late, i know, but who knows, maybe this will help someone else.
I realized that what PyDAQmx does is basically talk to the NIDAQmx driver's C-API via Python's ctypes. Most of the wrapping functionality it brings isn't really needed for such a simple task, or at all helpful regarding the actual problem there, which is: how do you use this C-API, i.e., which functions to call?
Neither looking through the documentation for NI USB TC01, nor the example codes for C-API posted earlier, nor anything else I was able to come up with from NI websites helped me here, so this was a rather frustrating experience. Again, this is a problem of bad documentation on the side of NI, not one of "open source" or "not enough effort put in it" (or anything else of the troll bs posted here).
I finally managed to make it work, using the example code from Scipy cookbook and tinkering around with the exported functions from the dll, using the header file (NIDAQmx.h).
Here's the code.
Requires: Python 3, ctypes, numpy,  nicaiu.dll (obtained from NIDAQmx 15 runtime, in my case).
import ctypes
import numpy as np
import os
class NiUsbTC01:
    # type mappings
    int32 = ctypes.c_long
    uInt32 = ctypes.c_ulong
    float64 = ctypes.c_double
    # constants mappings
    tc_types = {
        "J" : 10072,        # DAQmx_Val_J_Type_TC
        "K" : 10073,        # DAQmx_Val_K_Type_TC
        "N" : 10077,        # DAQmx_Val_N_Type_TC
        "R" : 10082,        # DAQmx_Val_R_Type_TC
        "S" : 10085,        # DAQmx_Val_S_Type_TC
        "T" : 10086,        # DAQmx_Val_T_Type_TC
        "B" : 10047 ,       # DAQmx_Val_B_Type_TC
        "E" : 10055,        # DAQmx_Val_E_Type_TC
    temp_units = {
        "C" : 10143,        # DAQmx_Val_DegC
        "F" : 10144,        # DAQmx_Val_DegF
        "K" : 10325,        # DAQmx_Val_Kelvins
    def __init__(self, device_id="Dev1", channel_id="ai0", tc_type="K", temp_unit="C", temp_min=-50, temp_max=100):
        # load the DLL
        nidaq_dll_path = os.path.join(os.path.dirname(os.path.realpath(__file__)), "bin/nicaiu.dll")
        self.nidaq = ctypes.WinDLL(nidaq_dll_path)
        # alternatively, if runtime is installed & registered:
        # self.nidaq = ctypes.windll.nicaiu
        self.task_handle = self.uInt32(0)
        physical_channel = "{}/{}".format(device_id, channel_id)
        # reset device
        self.nidaq.DAQmxResetDevice(device_id.encode("ASCII"))
        # create task
        self._nidaq_assert(self.nidaq.DAQmxCreateTask(b"", ctypes.byref(self.task_handle)))
        # create channel
        self._nidaq_assert(self.nidaq.DAQmxCreateAIThrmcplChan(
            self.task_handle,
            physical_channel.encode("ASCII"),
            b"",
            self.float64(temp_min),
            self.float64(temp_max),
            self.temp_units[temp_unit],
            self.tc_types[tc_type],
            10200,             # DAQmx_Val_BuiltIn   //  CJC Source "Built-In"
            self.float64(0),
            b""
        # start task
        self._nidaq_assert(self.nidaq.DAQmxStartTask(self.task_handle))
    def __del__(self):
        try:
            self._close_task()
        except:
            pass  # worth a try
    def _close_task(self):
        if self.task_handle.value != 0:
            self.nidaq.DAQmxStopTask(self.task_handle)
            self.nidaq.DAQmxClearTask(self.task_handle)
    def _nidaq_assert(self, err):
        """Raise Exception if return code 'err' is not 0."""
        if not err == 0:
            buf_size = 300
            buf = ctypes.create_string_buffer(b'\0' * buf_size)
            self.nidaq.DAQmxGetErrorString(err, ctypes.byref(buf), buf_size)
            raise Exception('nidaq call failed with error {}: {}'.format(err, repr(buf.value)))
    def get_temperature(self):
        read = self.int32()
        data = np.zeros(1, dtype=np.float64)  # size 1 array, passed by ref to be filled
        self._nidaq_assert(self.nidaq.DAQmxReadAnalogF64(
            self.task_handle,
            1,                          # number samples per channel
            self.float64(1.0),          # timeout in sec
            0,                          # DAQmx_Val_GroupByChannel   // Group by Channel
            data.ctypes.data,           # the array byref
            1,                          # array size in samples
            ctypes.byref(read),         # samples per channel read (return value)
            None                        # reserved
        return data[0]
if __name__ == "__main__":
    sensor = NiUsbTC01()
    print(sensor.get_temperature())
Message 19 of 27
(2,921 Views)
Thanks a lot! I need to do it right now!:)
Message 20 of 27
(2,846 Views)
