QNX or Linux driver that will DMA from a PCI-6052E
I am planning a QNX or Linux driver that will DMA from a PCI-6052E.
In the readme at
ftp://ftp.ni.com/support/daq/linux/Readme
snip ..
* DMA is not supported at this time. Doing DMA would require
programming the mMITE chip on NI's CPCI/PCI/PXI cards, and as of now
that information is only available under NDA, thus precluding an
open-source release. Feedback on this issue is appreciated.
snip ..
Is this readme up to date? I do need the DMA, and was hoping to get the
necessary info from the Linux code.
cheers -- Rick
Rick Leir
Pelyco Systems
rleir at pelyco dot ca replace at and dot
Sent via Deja.com http://www.deja.com/
Before you buy.
Message 1 of 1
(3,609 Views)
