Question about USB-6361 with SCXI chassis
Now I have SCXI system contains with SCXI-1520 10 Modules and SCXI-1349 Now I use SCXI-1600 as DAQ to acquiring data to computer. I have a question. Can I use USB-6361 Mass termination instead of SCXI-1600 to acquiring data and control SCXI chassis?
(2,288 Views)
The USB-6361 is actually the recommended replacement for the SCXI 1600. If this is the only SCXI module you are replacing, go for it. Otherwise, you may want to into the CompactDAQ platform.
https://www.ni.com/en/support/documentation/supplemental/17/obsolescence-planning-for-several-legacy...
(2,259 Views)
