Question about using non ni devices
Hi , i am making an installer for my application using MCC PCI DAS 1002 , Multifunction DAQ . The code works fine in the development environment. But , when deployed to the target pc ( which doesn't have the labview installed) , the application can't connect to the DAQ, although the driver is installed.
Is there any aditional installers that i must include , for the application to work?
Thanks in advance.
(2,952 Views)
It sounds like you need to install LabVIEW Run-Time Engine on your target PC. You should download the Run-Time version that corresponds to the development version. e.g. if you develop in LabVIEW 2015, download LabVIEW Run-Time Engine 2015 on the target.
You may also want to contact MCC to see if there are any other considerations to take for running your application on another computer.
Josh
(2,880 Views)
