Question about waveform generation and oldDataStop
HI,
The question I have concerns the: implications of error codes when
enabling oldDataStop during the generation of waveforms. I would
greatly appreciate any insight anyone may have on the questions
I note below.
While the documentation provided by National Instruments is fairly good,
it does not discuss which of the many error codes are warnings rather
than errors, and what an application should do when one of the
errors is detected.
Background
I am using a PCI-6713 board to regenerate a waveform that I previously
sampled using a PCI-6052 data acquision system. I am using double-
buffered waveform generation. Because I want to generate a given
portion of the waveform only once, I
have configured the PCI-6713 to
not allow the regeneration of old data (i.e., I set oldDataStop = 1 in the
call to WFM_DB_Config).
Questions
I have noticed that when I enable oldDataStop calls to WFM_DB_HalfReady
and WFM_DB_Transfer return errors. In particular, the error codes
I have seen are:
-10608 (noTransferInProgError) returned by wfm_db_halfready
-10803 (transferStoppedError) returned by wfm_db_transfer
My questions:
- In the case of wfm_db_halfready, how do I restart the waveform
generation? When error -10608 is returned by this function, the
half-ready output flag is not asserted. Thus, it does not appear that
I can just ignore the error.
- In the case of wfm_db_transfer, I have been ignoring the resulting
error. Should I be?
- Are there other errors I may encounter by turning on oldDataStop
of which I should be aware?
Again, any help would be greatly appreciated.
-Keith
(3,365 Views)
We experience erroneous errors -10403 when oldDataStop=1.
_db_check also doesn't work well if oldDataStop=1
Nidaq 6.51,6.6,6.7.
Phil Salamone
Keith Farkas wrote:
> HI,
> I note below.
> errors is detected.
> Background
> portion of the waveform only once, I have configured the PCI-6713 to
> Questions
> I have seen are:
> My questions:
> error. Should I be?
> -Keith
(3,365 Views)
