Question(s) about cable length and communication beteween DAQ-devices...
I just saw the newslettter with the article about an ROV submersible. Now I have some questions about the communication between remote daq devices and the central computer.
I want to use five DAQ-devices, in a serial arrangement, with about 100 m cable between the single devices. The cable is just plain telephone cable, and the power supply as well as all communication has to go through the cable.
SensorArray#1 - [ 100 m cable - SensorArray#2-5 ] - 100 m cable - Control PC/Power supply.
At each sensor array several values are recorded (pressure, temperature, light intensity, and others, with some with a acquisition rate of at least 3 kHz).
I wonder which is the best, and which is the cheapest way to control these 5 sensor arrays over one cable over a maximum distance of 500 m. I think for CAN the handbook says that 500 m is the limit in thick cables, but telephone cables are quite thin. There is a significant drop in voltages above 500 m, as they have I think 4 Ohm resistence per 100 m.
I was thinking about 5 remote PC/104 computers, which are communicating with the control PC via LAN or serial (RS-485) communication, or with CAN? All the equipment in the arrays has to be powered by power through the cable, so I think there might occur some interference? As I have no background in this kind of cabling/communication, I wonder if somebody here could argue in the one or other direction?
Thanks a lot!
(2,802 Views)
Hallo Herr Schröder,
das klingt nach einer recht interessanten Anwendung und mir fallen dazu mehrere Lösungsansätze ein (z. B. Wireless DAQ, Distributed cRIO,...). Allerdings wäre es etwas mühsam die unterschiedlichen Optionen über dieses Forum zu diskutieren. Ich denke, ein direktes Gespräch wäre hier effizienter.
Bitte schreiben Sie mir eine Email (jochen.klier@ni.com), damit ich Kontakt mit Ihnen aufnehemen kann.
Mit freundlichen Grüßen,
Jochen Klier
(2,786 Views)
