R Series 7820R card simulation
I would like to simulate a PXIe-7820R(R series) in MAX as well as LabVIEW project. But couldn't find it in the choose device listbox in MAX. In LabVIEW project, device selection is empty, there is no devices populates under Rseries in Target &devices selection. why? how to simulate a PXIe-7820R R series card? Kindly help me sort out the issue.
Iam using LabVIEW 2021 Sp1
Thanks in Advance
regards,
Magesh
(1,229 Views)
You cannot do it under NI MAX, but you can run the FPGA code in simulation under your project.
Santhosh
Soliton Technologies
(1,214 Views)
Testing and Debugging LabVIEW FPGA Code
Simulating the FPGA Targets Using the Project Explorer In LabVIEW
Using the LabVIEW FPGA Desktop Execution Node
https://tmesystems.net/
(1,204 Views)
