RTD sensing with a 6023E device
Is it possible to perform RTD monitoring with a 6023E DAQ with no SC device (only conections block SCB-68)?
(2,596 Views)
You can use SCB-68 to connect the sensors which do not need any type of excitation. But if you see RTDs or strain gauges, they need current and voltage excitations which the SCB-68 does not provide.
The following links may be helpful.
Link 1
Link 2
Link 3
Sincerely,
Sastry V
(2,596 Views)
