RTX Support for PCI-6259 capture card
With regards to the National Instruments PCI-6259 capture card as described in:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14128
Are there device drivers to support the IntervalZero RTX 2009 Windows subsystem?
We're currently using the RTX 2009 realtime subsystem under Windows XP and require either a device driver or hardware documentation to allow a device driver to be developed. Standard WIndows driver will not work in the RTX realtime environment.
According to IntervalZero, there was support up to RTX 8.0 on the PCI-6259, but we're now using RTX 2009. Are there drivers to support RTX 2009?
Thanks.
(3,582 Views)
Good morning DAQ_Dude,
The latest DAQmx 9.1 Readme file does not mention any RTX support.  The latest support mentioned for RTX Support from this KnowledgeBase  article describes using older versions of LabVIEW such as 8.0 and 8.2.  There is also another KnowledgeBase article that describes using the DAQmx Base driver for support on RTX devices.  The latest DAQmx Base driver version 2.1 supports the RTX platform.  In that Readme file, you can see the devices supported by the driver for RTX.  However, our newest versions of DAQmx Base 3.3 no longer include support for RTX as mentioned in the Readme files.  There is not any documentation internally that discusses the Interval Zero RTX subsystem support directly, but rather RTX support as a whole.  Here are some documents that also might be of use:
LabVIEW Real-Time Module:
https://www.ni.com/en-us/shop/product/labview-real-time-module.html
LabVIEW Real-Time Module Manual:
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/user-manual-welcome.html
Best,
Adam
Academic Product Manager
National Intruments
(3,558 Views)
